Cameras keep going forward an hour
wittaj
Joined
Apr 28, 2019
Messages
25,380
Reaction score
49,435
Location
USA
OK I have the 49425 and it doesn't exhibit that behavior.
I think what @Teken said above is a good next step. Take one of these cameras off your network and isolate it and see if it holds. At this point the only thing I can think of is the NVR or IVMS or something else is throwing code at the camera causing it to change.
naamang
Joined
Apr 24, 2024
Messages
19
Reaction score
1
Location
South Bend, IN USA
I can find a single port injector around here somewhere tomorrow and give that a shot but don't know what that will accomplish if it does fix it. None of my NVRs or iVMS are configured to sync time with the cameras, I unchecked the time sync box on all three. Thanks for the assistance. I may have to just live with it this way.
wittaj
Joined
Apr 28, 2019
Messages
25,380
Reaction score
49,435
Location
USA
If it works, then you know it isn't the camera and is some other device/program that is causing it. That is what I am leaning towards since you have it on multiple cameras.
We have seen that with BI and the Dahua PTZs - even though BI isn't supposed to be able to change Motion Detection, it will turn Motion Detection on in the Dahua PTZs.
Many of us here were struggling with why did it keep enabling. Once we tested it isolated, it stopped being turned on. Hooked it back into BI and the check box would enable.
So now we set the MD to 1 block and the least sensitive and added a schedule of no time so that it can get enabled all it wants but it doesn't trigger the camera.
Flintstone61
Joined
Feb 4, 2020
Messages
6,688
Reaction score
11,079
Location
Minnesota USA
Ihad this issue for awhile with 4108 Amcrest NVR( DAhua OEM) and an Amcrest XVR, where by the NVR was " the Boss" of " Time keeping" and the cameras were like "slaves"
I forget how i figured out how to stop it....let me check some things.
turn off the NTP and DST check boxes on the Cams and let the NVR be the Boss of time...see if the NVR can take over the duties.
I think thats how i got it to quit acting up....Give the NVR an NTP address of your PC or from NetTime app
Flintstone61
Joined
Feb 4, 2020
Messages
6,688
Reaction score
11,079
Location
Minnesota USA
my cams are now " off the bossy NVR" and thusly no longer " slaves" to the NVR, because they are on a POE switch ( 192.168.0.xxx) with a different IP address than the internal NVR POE switches 10.x.x.x
I don't recall how I sorted this all out,,,,but since last fall, all the devices appear to be staying in Sync. my PC is 192.168.0.43
I see i have some housekeeping to do my DST 2024 end dates.... also 1 cam is on a default NTP server assigned by Amcrest at Clock.ISC.org.fuckyou you never worked right...:)
naamang
Joined
Apr 24, 2024
Messages
19
Reaction score
1
Location
South Bend, IN USA
View attachment 193175View attachment 193176
I'm a bit confused. You said in your first post to uncheck the NTP & DST boxes on the cameras and sync with the NVR that syncs with my PC via NetTime. Then in your last post you're showing most of your cams having the NTP & DST boxes checked and the cams syncing with your PC via IP? Is the NetTime software retrieving the time from an online server then making that time available to the NVRs and cameras via the PC's IP address? I have two NVRs, one Dahua and one Hikvision. I also have Dahua & Hikvison cameras and everything is connected to a 16-port POE switch. So I'm thinking configuring each camera to sync to the PC may be the better solution for me, eliminating any conflict between the two brands of NVRs.
saltwater
Getting comfortable
Joined
Oct 6, 2019
Messages
488
Reaction score
633
Location
Melbourne, Australia
Yes, setup your local computer as the time server, use the NetTime program referred to a few posts above, then in each camera settings enter the IP address of your local computer, the port number should be 123. It should work, it works for me. Caveat, I don't use a traditional NVR, I'm a Blue Iris guy, and my Blue Iris computer is the time server, where the NetTime program is installed and running. Dahua branded cameras do not have a 'test' button to check the success of NTP connection, but Hikvision branded do. You could try this prior to connecting your camera back into the NVR, just to see if it works.
naamang
Joined
Apr 24, 2024
Messages
19
Reaction score
1
Location
South Bend, IN USA
Thanks. I read on the NetTime website to ensure that the Windows Time Service is disabled along with any other NTP servers but didn't say how to do this. Did you have to do that to get this to work? If so, how do I go about doing that?
saltwater
Getting comfortable
Joined
Oct 6, 2019
Messages
488
Reaction score
633
Location
It's been a while since I did it, but if you go to SETTINGS > TIME & LANGUAGE > DATE & TIME you can turn off Windows setting the time automatically.
Mike A.
Joined
May 6, 2017
Messages
3,844
Reaction score
6,424
That won't kill the service. What happens is that the Windows time service will grab the port (123) that NetTime also uses. So you need to disable the W32Time service.
Bring up Task Manager, at the bottom click on Open Services. Scan the list for Windows Time. Right-click and select Properties. For Startup type, select disabled.
saltwater
Getting comfortable
Joined
Oct 6, 2019
Messages
488
Reaction score
633
Location
It's been a while since I did it, and I had a sneaking feeling there was something else.
naamang
Joined
Apr 24, 2024
Messages
19
Reaction score
1
Location
South Bend, IN USA
Thanks
Top
