Need help setting up OpenVPN with fiber optic
Chase
Joined
Feb 12, 2017
Messages
153
Reaction score
28
Location
Ohio
So I just switched from cable to frontier fiber optic now using the Eero Pro 6e mesh system.
On my old setup I was using the Asus RT-AC1750 router which has the built in OpenVPN server.
I want to keep using OpenVPN so I can keep my cameras offline from the internet and not port forward them.
I am not sure how I can do this though. Can someone who has done this before help and walk me through this? Is it even possible?
wittaj
Joined
Apr 28, 2019
Messages
25,380
Reaction score
49,435
Location
USA
Instead of the router hosting OpenVPN, you install it on a computer.
Chase
Joined
Feb 12, 2017
Messages
153
Reaction score
28
Location
Ohio
Forgot to mention that I run a dahua nvr and not blue iris. Not sure if that changes anything.
flynreelow
Joined
Dec 12, 2016
Messages
1,262
Reaction score
1,147
The Automation Guy
Joined
Feb 7, 2019
Messages
1,422
Reaction score
2,827
Location
USA
You can also check with your service provider (Frontier) to see if their demarcation hardware (ie the modem/router) supports a "bridge" or "pass through" connection. If they do, you can use your own firewall/router to handle all your network security including VPN. In other words, you can go back to using your old hardware. You'll just need to ensure the WAN connection is set up correctly for the Frontier connection. That being said, it probably would work just by plugging it in as most of these connection just use DHCP now, so it would automatically connect to a new WAN network without issues.
If you want to use the new Eero Pro 6e mesh APs, just turn off the WiFi transmission in the Asus RT-AC1750 router and plug the Eero system into one of the network plugs on the Asus (or whatever switch you are using).
Joined
Mar 7, 2019
Messages
472
Reaction score
1,063
Location
Missouri
So far I’ve managed to get ZeroTier working with T-Mobile 5G home internet.
Moved it to an empty port on my dual WAN router, changed the Managed Route in ZeroTier and have it working on there now.
There’s probably settings I don’t have quite right but so far OpenVPN through my router seems to work better for me. When I flip the switch in the OpenVPN app on my phone as soon as it connects (in seconds) I can open DMSS and the cameras load. With ZeroTier it may take a minute or longer before anything actually loads, once it connects it seems to work ok and has been stable.
Still have lots to learn and figure out with the unit. Such as WireGaurd for one but I started with ZT to see if it would work with T-Mobile and I would call that a success since there’s not many options with them
Chase
Joined
Feb 12, 2017
Messages
153
Reaction score
28
Location
Ohio
PiVPN with wireguard
I’m still trying to figure all this out. Just wish there was a simple solution. I’m tempted to just port forward but I know everyone says not to.
What would you say is the best pivpn (without WiFi) that won’t break the bank. Best place to buy as well. Amazon?
I believe this should work if you don’t have an always on computer. I just ordered one to see about getting OpenVPN off my router to lighten the load on it and try out WireGaurd
Or would this be the way to go?
I only want it to handle the VPN part of it. Keeping it as simple as it can be.
I’m not super tech savvy so bear with me regarding all my questions.
Joined
Mar 7, 2019
Messages
472
Reaction score
1,063
Location
Missouri
The Brume 2 is still working out for me. Using WireGuard with the device just sitting on my network only using the wan port, nothing attached to the lan port
flynreelow
Joined
Dec 12, 2016
Messages
1,262
Reaction score
1,147
set this up first on the PI
then follow that video above. its pretty easy.
bigredfish
Joined
Sep 5, 2016
Messages
17,764
Reaction score
49,415
Location
Floriduh
I use this and I think it rocks. Very flexible. I'm using Wireguard on it currently
VERY simple to setup and manage even for network dummies like me.
I dont use it as a router, left my Netgear in place.
flynreelow
Joined
Dec 12, 2016
Messages
1,262
Reaction score
1,147
360 bucks vs a 40 dollar Pi.
seems a bit crazy
bigredfish
Joined
Sep 5, 2016
Messages
17,764
Reaction score
49,415
Location
Floriduh
Doubtful they have the same features,I could buy $39 Chinese cameras too ;)
mikeynags
Joined
Mar 14, 2017
Messages
1,035
Reaction score
940
Location
CT
You can also just put your Asus in place of the Eero. That’s probably the easiest option for you.
flynreelow
Joined
Dec 12, 2016
Messages
1,262
Reaction score
1,147
yea, most of the same features.
u run piVPN and pihole.
doesnt have a hot spot, but there may be an add on of somesort.
tangent
Joined
May 12, 2016
Messages
4,441
Reaction score
3,694
You could keep the RT-AC1750 doing the routing and VPN (if it can handle your fiber speeds), turn off it's wifi, and use the Eero system as access points.
bigredfish
Joined
Sep 5, 2016
Messages
17,764
Reaction score
49,415
Location
Floriduh
Dude, scroll down this page, if a $40 Pi can do all of that natively including the interface and app, I'll buy one tomorrow. Heck I'll buy 2!
flynreelow
Joined
Dec 12, 2016
Messages
1,262
Reaction score
1,147
not sure if you have ever worked with a RasPi before.. they are amazing devices. but def harder to set up. of course you are going to spend more money on an item like yours thats turnkey right out of the box.
Chase
Joined
Feb 12, 2017
Messages
153
Reaction score
28
Location
Ohio
So I went with the Brume 2 unit, hooked the WAN cable from the modem to the WAN cable on the brume, then the lan from the br to the computer.
Set up just fine, logged in fine, setup WireGuard fine and installed on phone. It says it has connection but I can’t get back to my network.
I probably need to do something else as this was all I did.
Setup as Modem > Brume > Eero Gateway
Only thing i can notice is the ipaddress on the brume is different than the eeros. Specifically, the 3rd number. x.x.8.1. Do these need to match?
Top
